Also, note that many (if not most) 50-ohm output generators (function, audio, RF, pulse, arbitrary-waveform, etc.) are calibrated for the voltage across the 50 ohm external load.
With a high-impedance load (such as 1 megohm 'scope input), the voltage will be twice that.
