On the 2 that I have owned, the channel trace colors were fixed. The front panels have the inputs color coded and this is permanent, so changing the trace colors on the screen doesn't seem like a good idea.
Also, you tend to adjust a probe for a particular channel and attach a colored tag to the probe so that the probe color, front panel color, and the trace color all match up and it is easy to know what you are looking at.
