Assuming an hFE of 40, I did a little MATLAB thing to figure out what the base resistor should be. I am also going to assume VceSat = 0.2V and Vb = 0.7V. In any event, I come up with around 20k Ohms for the base resistor to get the device into saturation. If I were to actually build the circuit, I would use 10k just to make absolutely sure I got the transistor into saturation.
[font=courier]
format shortEng
format compact
Vcc = 5.0 % given
Vsignal = 1.0 % given
VceSat = 0.2 % assumed
Vb = 0.7 % assumed
R2 = 8200 % given
VR2 = Vcc - VceSat
IR2 = VR2 / R2
Ib = IR2 / 40 % assumed hFE = 40
VR1 = Vsignal - Vb
R1 = VR1 / Ib
[/font]
The results look like:
[font=courier]
Vcc =
5.0000e+000
Vsignal =
1.0000e+000
VceSat =
200.0000e-003
Vb =
700.0000e-003
R2 =
8.2000e+003
VR2 =
4.8000e+000
IR2 =
585.3659e-006
Ib =
14.6341e-006
VR1 =
300.0000e-003
R1 =
20.5000e+003
[/font]
This little arithmetic problem will also run in the free Octave (I believe based on other tests).
Biasing to use the transistor as a common emitter amplifier is an entirely different matter. Here the issue is just to create an inverter.
