I am having trouble understanding the behaviour of my zener diodes. I suppose I am missing some pracitical understanding how this thing really works.
Maybe someone can explain, would be great.
I have here a whole bunch of 3.3 volts zener diodes. They are sold with name "ZF 3.3" by some german vendor (reichelt.de), but these are in fact BZX79C 3V3 .
My simple understanding is, that a Zener diode regulates output voltage between Kathode and Anode. If a voltage is put there (plus to Kathode, Minus to Anode). And if the current has some required value,
the output voltage is around the value printed on the diode.
From the BZX79C datasheet, I can see that the required current is 5mA. Then the diode should regulate and output a voltage between 3.1 and 3.5 volts.
So I have created a simple test, with a 330 ohms resistor, the zener diode and put some voltage on it. I have high quality power supply and measurement devices, so I played around to get 5mA current flow.
The voltage measued then between K and A of the diode was 3.936 volts. Expected was, as said, something between 3.1 ... 3.5 volts.
I tested several of my zener diodes, they all have a behaviour like this. So it is not due to a single broken one.
I tried this with 3 different power sources, all linear regulators. AC ripple can be ruled out I think.
To summarize. I set up the diode to get the current it needs for the desired output. But voltage output is higher. Why? How to set up the diode that it outputs/regulates to 3.3 volts?
Try to visualize the test curcuit:
Vcc, about 5.64 volts o------R=330 Ohms ---(K)--|<|---(A)----o GND
Amperemeter is between Vcc and resistor, voltmeter between K and A.
Dennis
