Hi Everyone!
Long time lurker, first time poster! I have a question that could use some clarification. I've recently gotten into electronics because I've been building joysticks for my old Atari 2600, Before buying a soldering station, I watched many on-line tutorials. I've noticed that people use different methods when soldering, i.e twisting wires together, pre-tinning and then joining wires, "western union" joints, etc..., but one thing has me confused. In the video below, the person demonstrating says that, when joining two wires, your solder and the tip of your iron should never make contact. That is, you hold the iron below the wire, heat up the wire, and then bring the solder to the wire, making contact only with the wire and not with the tip at all. He says this around the 3:20 point.
In other videos, like the next one, the narrator says to have your solder touch the tip of your iron, where the tip and the wire meet. He says this at around the 4:50 mark of the video:
Is one of these methods wrong? Are both correct? This has been bugging me. I want to make sure I'm soldering correctly. Thanks so much for your advice and help!
