Author Topic: sdram autorefresh ??  (Read 1580 times)
Offline 5282Topic starter
« on: November 30, 2016, 01:56:17 pm »
   self refresh the row address is increment by internal oscillator.
    so
    1- in auto refresh the row address is increment by internal oscillator or my external clock in ?
    2- in auto refresh row address increment internal automatically counter or i change row address by external command?
    3- auto refresh need minimum time or minimum clock cycle to end
    because i find in data sheet it need minimum time not minimum clock cycle ?
    4- precharge command can use it instead of auto refresh. if i will not use all sdram size capacity . to refresh some little row in bank
Re: sdram autorefresh ??
« Reply #1 on: December 02, 2016, 08:38:04 am »
are there problem in my question it is not clear ?
