Hello there,
I have a couple of questions I found hard to get answered whilst searching the web:
1. If I model offset voltage as a voltage source in series with one of the inputs, how to I learn from the datasheet: in series with which input should it be modelled,and of which polarity is it?
2. I model offset current as a current source from one of the inputs. How do I determine which input? Is the polarity of the input current affected by the type of input transistor? Or does the polarity of the input current tell the engineer which input the bias should be modelled at, or both?
Thanks.M
