Hi everyone,
I just have busted main transformer :
https://www.eevblog.com/forum/product-reviews-photos-and-discussion/hameg-hm8130-function-generator-teardown-and-repair/I just unsoldered today and double checked it.
It has two primary wirings for 110v (parallel them) and 220v (put them in series). One primary has 43ohms and the other one 10kOhm, this one is broken. If plugged, the main fuse keeps blowing.
The secondaries seems to have "normal readings" of a few ohms.
Hopefully, Hameg stocks the spare, so I can replace it.
Yet, I'd like to find out what caused it to break. So as not to buy a new transformer and break it to.
I was basically using the generator and it just shuts down (fuse blown), some sort of sudden death.
There is a line filter before the transformer, I've checked it, it seems ok.
All secondaries are connected to the usual rectifier and filter caps. They seem ok too.
Then they all go to voltage regulators, standard 7805, 7815, 7915, and L200.
I'm a little bit puzzled as the 78xx series are supposed to have current limiting. So even in case of a short on the main board, the transformer should be protected.
Any idea ?
Best regards,
