Let's pretend I got a Voltage of 50V, GND, -50V and want to put it into something with PWM, using Mosfets. The problem is, that the Mosfet has a capacity and will not instantly turn off, if there is no more voltage supplied. If I would put a negative Voltage to the Gate/Source, would the MOSFET turn and stay of, or would a negative Voltage applied also turn the MOSFET on? I will use a trigger Voltage of about 10-12 Volts. Not sure exactly.
