Author Topic: Processing to Arduino  (Read 3040 times)
Offline BrownTopic starter
« on: June 16, 2014, 10:31:48 pm »
Hi, I need help connecting my Processing sketch to my Arduino sketch. How do I sent the date, temp , weather, and woeid variable from Processing to Arduino. Thanks
Arduino Code:
//LCD Setup
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup() {
    //Serial Setup
Serial.begin(9600);
  Serial myPort;
    //Port setup
  myPort = new Serial (this, "COM3", 9600);
  //LCD Setup
  lcd.begin(16, 2);
void loop() {
  int inByte = Serial.read();
  lcd.println(inByte);
Processing Code:
// Serial Comm with the Arduino
import processing.serial.*;
Serial myPort;
//variable used to store the temperature
int temperature = 0;
//Using 'date' as variable to store data
String date = "";
// store weather data
String weather = "";
String woeid = "24124932";
PFont font;
void setup() {
  size(600, 360);
  font = createFont("Georgia", 28);
  textFont(font);
  String url = "http://weather.yahooapis.com/forecastrss?w=" + woeid;
  // Loads the XML
  XML xml = loadXML(url);
  // Gets the XML element
  XML forecast = xml.getChild("channel/item/yweather:forecast");
  XML title = xml.getChild("channel/item/yweather:condition");
  // Get the attributes we want
  temperature = forecast.getInt("high");
  weather = forecast.getString("text");
  date = title.getString("date");
void draw() {
  background(255);
  fill(0);
  // Display all the stuff we want to display
  text("Last Updated: " + date, width*0.15, height*0.33);
  text("Today’s high: " + temperature, width*0.15, height*0.5);
  text("Forecast: " + weather, width*0.15, height*0.67);
  text("WOEID: " + woeid, width*0.15, height*0.84);
  myPort.write(date);
Re: Processing to Arduino
« Reply #1 on: June 16, 2014, 10:36:31 pm »
Basically, all I want to do is send a variable from Processing to Arduino
Offline Rick Law
« Reply #2 on: June 17, 2014, 02:13:54 am »
Arduino Code:
//LCD Setup
void setup() {
    //Serial Setup
Serial.begin(9600);
  Serial myPort;
    //Port setup
  //LCD Setup
  lcd.begin(16, 2);
etc. etc...
What model Arduino and IDE are you using?
"COM3" is a PC side thing, on the Arduino, it is Serial. Serial1 (for the MEGA)...
Try using their example and see if it works just to test out the connection.
Also, what are you using on the PC side to receive? (A VT100 emulation will work just fine if you want to see if things are coming in as expected.)
« Reply #3 on: June 24, 2014, 02:24:23 pm »
Arduino IDE 1.5.6-r2
So, I got it to work, but I can only send one variable. I want to send multiple variables and strings. How do I do that?
I can only send one variable, in this case temperature , from Processing to Arduino
Arduino code:
//LCD Setup
void setup() {
    //Serial Setup
Serial.begin(9600);
  //LCD Setup
  lcd.begin(16, 2);
void loop() {
  //Reading the variable that's coming from Processing
  //Setting the cursor so 'Today's High (C):' is on the top line
  lcd.setCursor(0, 0);
  //Prining 'Today's High (C):' on the LCD
  lcd.print("Today's High (C): ");
  //Setting the cursor so value is on the bottom line
  lcd.setCursor(0, 1);
  //Delay
  delay(500);
  //Printing the value
  lcd.print(inByte);
Processing 2.1.2
//LCD Setup
void setup() {
    //Serial Setup
Serial.begin(9600);
  //LCD Setup
  lcd.begin(16, 2);
void loop() {
  //Delay
  delay(500);
  lcd.print(inByte);
« Last Edit: June 24, 2014, 02:28:08 pm by Brown »
Offline retrolefty
« Reply #4 on: June 24, 2014, 02:45:48 pm »
void loop() {
  //Delay
  delay(500);
  lcd.print(inByte);
 The fatal flaw in your reading of serial data is that you must first perform a test to see if a serial byte is indeed available to be read before actually reading it. The arduino serial library is fully interrupt driven and buffered for both send and receive data. Also serial comm is a single byte at a time process and if your variables are multi-byte in length you must perform your own parsing using whatever protocol you have defined. Here is an example from the arduino serial reference page showing the proper method to read a single byte from the PC:
void loop() {
        // send data only when you receive data:
        if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.read();
                // say what you got:
                Serial.print("I received: ");
                Serial.println(incomingByte, DEC);
http://arduino.cc/en/Reference/Serial
