The output should never rise above the set point when power is applied or removed. I am inclined to believe that there is more than one problem but the lack of any regulation or protection on the supply to the operational amplifiers I consider a design flaw.
That's kind of what I was thinking. The design has never really worked from what I can tell. Reading the lengthy thread(s) on the design gives people that have had success building the thing but I don't think anyone has really tested it until very recently. One of the members over there just recently got a DSO and tried to solve the transient issue with the addition of the voltage regulator but I think he only tested within a certain range and reported it solved. It wasn't. I'm about ready to give up on this one for awhile and see if I can get something better going with a bit more research.
Usually these problems are caused by improper startup and shutdown sequencing but linear power supplies are generally simple enough not to require complex solutions.
Any word on a vetted design that would be relatively simple that I could perhaps use the two 28V 4.3A transformers with? I was shooting for 30V @ 3A but I also just got, in addition to the 301A's, OP07's and TL071's, a single primary, dual secondary transformer that can do 36V @ 1A series, 18V @ 2A parallel or 2X18V @ 1A independently. I was thinking 0-18V @ 1A positive and negative until I can figure out this other issue, I just need a proven design that won't set me back too much.
The only kit power supply I have is 723 based and 20+ years old. Since then I have usually designed and built my own as needed.
I did a quick search online and did not find an designs or kits I would recommend. Variable constant voltage constant current designs tend to be as complex as the comparable Tektronix or HP implementations.
The PS-503 design is pretty dense and unconventional in some respects even if you ignore the complexity added by being a dual output design with tracking. There are changes I would make like having the output amplifiers operate with a fixed gain and varying the output from the reference because it would make the frequency response more predictable.
Yeah, looking at it kind of intimidates me a little. I'm sure everything they did had a purpose at the time and I'm sure there are modern designs that run circles around it but I think simple would be better for me until I learn more.
The Tektronix and HP/Harrison designers certainly knew what they were doing and were thorough. HP bought Harrison Laboratory Company in 1962.
Any performance limitations are more from application limits then an old design. Modern designs intended for the same applications are not going to perform any better at least in a practical sense.
The PS-503 has simple zener shunt and series regulators to protect the control circuits from high voltages. It has other design features which look like they were intended to prevent startup and shutdown glitches but the manual only discusses one of them.
The similar HP/Harrison 6236 which is a more straightforward design has its own protection circuits. From its manual:
4-11 The turn-on/turn-off control circuit prevents output
transients when the supply is turned on or off. It does this by
delaying the application of certain bias and reference voltages
at turn-on and removing them shortly after turn-off.What I really want to learn is the analog side of things. When I was a kid and used to take things apart, the electronics always intrigued me but I never really did anything with it. Up until a few years ago I even had a few of those big assed aluminum variable capacitors. Digital wasn't here yet and I'd like to start with much less than a microcontroller.
Even complex power supplies are simple enough that they are a great place to start learning electronics.
Some multimeters have a pretty fast peak detect mode.
Any storage oscilloscope is handy in cases like these. DSOs are particularly useful for diagnosing startup problems and even an old and low performance unit can handle something like this. I very rarely need to use anything better than a Tektronix 2230 which is the oldest DSO that I can honestly recommend.
I would never recommend a USB DSO unless it had a unique and useful feature like the ones from CircuitGear which support low frequency vector network analysis. That is particularly useful for designing high performance power supplies.
The scope I have is ancient even by ancient standards. Behold, the Conar 255.
That
is very old. Even the lowest end of the inexpensive used analog oscilloscopes from Tektronix and others would be better but you need some type of storage to see glitches easily.
I've been keeping an eye out on Ebay but things go fast there and the resellers are a big problem. I figure if I'm going to spend over $200 I might as well wait and keep saving to get a DS1074Z.
The 2230 that I have I picked up on Ebay for about $100 but I would not recommend one for a beginner unless you have the option to return it; they are somewhat tricky to repair and maintain and are getting old. The 2232 is a lot better but tends to go for $300.
I have not used one but the CircuitGear USB DSOs I mentioned are interesting given their low cost. They are not particularly fast but they are certainly fast enough for power supply design and look like they were intended for a student environment.
The least expensive Rigol I would consider is the DS1074Z. I would absolutely avoid at least their B, CA, D, and E series oscilloscopes because they lack peak detection as I understand the term according to Rigol. The documentation for their Z and 2000A series oscilloscopes is not clear on the matter either and naturally nobody who has reviewed them has tested for what exactly they do support so I am dubious about them as well which just leads me to conclude that Rigol makes junk.
How can they design a modern DSO which supports peak detection or envelope detection but not both and
then screw up the documentation repeatedly by confusing the two? I complained about this to them years ago trying to get answers; at first they did not understand the difference and then they lied about it.
Every now and then I check craigslist but there never seems to be anything there which is either odd or not considering I live fairly close to Boston.
I am near St. Louis and see good analog and digital storage oscilloscopes show up on Craigslist about once or twice a year. I picked up a Tektronix 547 that way but missed a Tektronix 2232. I saw something like a Hitachi VC-6145 once and a Leader analog/digital CRT DSO but I prefer more common instruments with good service documentation.
Boston should have a larger market then St. Louis for used test equipment because of the technical industries in the area. You might want to check out the MIT swap meet.
I think I've found a solution that may help. I've seen the circuit in action on a video and it works but I simplified it a bit for my needs.
That just looks like a soft start circuit. Power supplies generally lack soft start circuits except for their current limit and small output capacitor.
