Well, I conclude that they are pretty useless for general purposes. If you want to use a voltage regulator to step down the voltage to lower value, 5V in my case, it will work up to some mA then the actual voltage would drop to 5V, therefore, the regulator would cause the voltage to drop below 5V (due to forward voltage of regulator).
