Really, it's only temporary for limiting the inrush current. It's not going to consistently pass a high current load for a long period of time. Looking at my sim, the max current passing through the resistor is approximately 1.7 amps for ~10 microseconds. Given a resistance of 8-ohms, that's a bit over 23 watts, well within the rated 35-watt limit. I wasn't planning to attach it to a heat sink. Worst case, I just use a larger resistor.
