Good day all.
I have been asked to look into if it is possible to adjust the volume output on a optical digital to analog audio converter.
The unit works as expected, but even with powered headphones plugged into the converter the volume output is below the desired level.
I have had a quick look inside the unit, as it seems that it is using a 4558 Dual Operational Amplifier, for the headphone output.
Now I have never done any work with op-amps before so I am not really sure where to start.
I will try and take some pictures and get them up here asap.
Can you please advice.
Thanks for your time.
Best Regards.
