Has anyone seen a power adapter tester for power bricks? I have about 2000 power adapters to test and was hoping to find or build something that could easily & safely be used by anyone. There are tons of different ATX power testers up on Amazon and was hoping to find something like this but geared towards two different barrel sizes. One of the adapters is 19v and the other is 19.5v, I don't necessarily see the need for a current test just voltage. I'm also considering making a breakout cable with the the female barrels that can hook up to an ATX tester but ideally I would like to find something specifically made for this test. Really surprised I'm having such a hard time finding one in a search.
Maybe I'm over thinking this. The more I search for this product on Google, Amazon, eBay etc the more I wonder if I should just purchase 2 sets of multimeter probe cables cut the probes off, solder a barrel connector to the end and plug it directly into a multimeter. Another possibility if I can find the parts is a Y splitter with 2 different size female barrels at the end (pre-made or soldered) that go to a female socket in which I can plug my probes into. Unfortunately I'm not even sure what the multimeter socket is called, seems to be a bannana socket but it's hard to tell in some of the pictures if the probe will be fully insulated. Seems like these options would work fine but not as flashy as a standalone unit.
Any ideas or suggestions?
Thanks,
Andy
