Looking from another perspective: since there is current through R15, there must be voltage drop on it. The base-emitter junction is a diode and in this situation is the primary element determining voltage at point #2, keeping it at 0.6–0.8V below +3.3V supply voltage, even without that the R15 would not allow the voltage to go to whatever is at point #1.
Here are some simulations in Falstad’s webapp to depict the situation. First, the BE diode being the primary factor determining voltage at #2:
simulation. Second, the voltage drop on the resistor:
simulation. The results of both in the attachments.
The corresponding sources for the simulations:
$ 1 0.000005 10.20027730826997 50 5 50 5e-11
d 288 160 256 192 2 default
R 288 160 288 128 0 0 40 3.3 0 0 0.5
w 256 192 192 192 2
i 192 192 144 192 0 0.001
g 144 192 144 208 0 0
g 144 272 144 288 0 0
i 192 272 144 272 0 0.01
w 256 272 192 272 2
R 288 240 288 208 0 0 40 3.3 0 0 0.5
d 288 240 256 272 2 default
g 144 352 144 368 0 0
i 192 352 144 352 0 0.1
w 256 352 192 352 2
R 288 320 288 288 0 0 40 3.3 0 0 0.5
d 288 320 256 352 2 default
g 144 432 144 448 0 0
i 192 432 144 432 0 1
w 256 432 192 432 2
R 288 400 288 368 0 0 40 3.3 0 0 0.5
d 288 400 256 432 2 default
d 288 480 256 512 2 default
R 288 480 288 448 0 0 40 3.3 0 0 0.5
w 256 512 192 512 2
i 192 512 144 512 0 10
g 144 512 144 528 0 0
R 368 160 368 128 0 0 40 3.3 0 0 0.5
w 304 192 240 192 2
i 336 192 304 192 0 0.000001
r 192 192 240 192 0 1500
w 368 160 336 192 0
w 192 192 144 192 0
w 192 272 144 272 0
w 368 240 336 272 0
r 192 272 240 272 0 1500
i 336 272 304 272 0 0.000009999999999999999
w 304 272 240 272 2
R 368 240 368 208 0 0 40 3.3 0 0 0.5
R 368 320 368 288 0 0 40 3.3 0 0 0.5
w 304 352 240 352 2
i 336 352 304 352 0 0.00009999999999999999
r 192 352 240 352 0 1500
w 368 320 336 352 0
w 192 352 144 352 0
w 192 432 144 432 0
w 368 400 336 432 0
r 192 432 240 432 0 1500
i 336 432 304 432 0 0.001
w 304 432 240 432 2
R 368 400 368 368 0 0 40 3.3 0 0 0.5
R 368 480 368 448 0 0 40 3.3 0 0 0.5
w 304 512 240 512 2
i 336 512 304 512 0 0.002
r 192 512 240 512 0 1500
w 368 480 336 512 0
w 192 512 144 512 0
