When the Weller TCP 'Magnastat' irons were king in the service and hand assembly trades, they were supplied as standard with the PTAA-7 bit which set the temperature to 700 deg F, (370 deg C). Although you could get bits with Curie point slugs in the range 600 deg F (315 deg C) to 900 deg F (480 deg C), with the exception of a chunky 5mm PTDD-8 800 deg F bit which was always handy to have for heavy terminals, the other temperature rating bits were pretty much special purpose only - 800 deg F and hotter bits were too much of a PITA to keep tinned for general purpose work unless you religiously switched the station off for even small pauses in your workflow, and 600 deg F bits didn't deliver enough heat for anything except the lightest of work with the normal SnPb alloys that were in common use in that era.
ive brought a few reels of supposed 60/40 leaded solder from uk ebay sellers,when it is delivered,says made in china on the reel,turns out its lead free rubbish,just sommat to look out for,had one guy wanted me to send him pics of the crappy looking joints,my reply was dont you know what a dry joint looks like?,in the end i got %50 of my money back,not the ideal solution tho!!.
I personally find its nearly as easy to work with good quality SnAgCu solders as with traditional SnPb solder. Pb-free <> rubbish.
Due to the relative market prices of Tin and Lead, its unlikely your crap solder was actually Pb-free. See my comments here:
https://www.eevblog.com/forum/reviews/soldering-question-tinning-16-awg-wire/msg3143318/#msg3143318.If you can also measure the melting point, you can identify the alloy supplied with a fair degree of certainty.
Sounds like an esd-issue or a reliability problem. The datasheet says it can be soldered with 300C for 10s. I believe these ratings are conservative.
At first, I also thought that it is an ESD problem. But if this was an ESD, those MOSFETs would be damaged at the same rate at low temperature too, and other similar MOSFETs would have same problems, but they were not and the same fault mode later confirmed with a different batch of parts in different setting.
Later we dropped BSS138 completely for 2N7002K.
It may have been a moisture problem - its *rare* to get popcorning when hand soldering (excluding refow), but with a high enough soldering temperature it can happen.
