Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
please help me with resistor identification question
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: please help me with resistor identification question (Read 1202 times)
krayvonk
Regular Contributor
Country:
on:
July 13, 2019, 03:13:35 pm »
I was wondering PLZ could someone post a pic of the resistor that is 4 times the resistance of this one ->
Logged
chemelec
Contributor
Country:
Re: please help me with resistor identification question
Reply #1 on:
July 13, 2019, 03:23:13 pm »
Color Pic is Not very clear.
Looks like Brown, Black, Red (1,000 Ohms) with a gold ring, so a 5% Tolerance.
4 Times would be a Yellow, Black, Red. (4,000 Ohms.)
But 4000 is Not a Standard Value. 3,900 is close. (Orange, White, Red)
Logged
krayvonk
Audioguru
Super Contributor
Country:
Reply #2 on:
July 13, 2019, 03:25:43 pm »
Your dim fuzzy photo seems to show brown, black and red bars which is 1k (1000 ohms). The gold bar is for a tolerance of 5%. There is no such resistor value of 4k (4000 ohms) but 3.9k (3900 ohms) is very close.
Logged
krayvonk
Audioguru
Super Contributor
Country:
Reply #3 on:
July 13, 2019, 03:28:43 pm »
Hi Gary. We Canucks think alike.
I was busy swearing at a caller on a phone call from India who was selling Duck Cleaning again and again and again.
Logged
krayvonk
krayvonk
Regular Contributor
Country:
Reply #4 on:
July 13, 2019, 03:48:00 pm »
Audioguru-> My name isnt Gary, but yes indian cleaning services are fricken annoying. But thanks all for the polite help! off I go back to work.
Logged
MagicSmoker
Super Contributor
Country:
Reply #5 on:
July 13, 2019, 04:02:18 pm »
You might find it useful to study/download a chart of the E12 (10% tolerance), E24 (5%), E96 (1%) and E192 (0.5%) number series, as these are used for standard part values with the tolerances indicated parenthetically.
Logged
krayvonk
ArthurDent
Super Contributor
Country:
Reply #6 on:
July 13, 2019, 04:24:21 pm »
Here is the simplest solution using what you have on hand.
Logged
krayvonk
bob91343
Super Contributor
Country:
Reply #7 on:
July 13, 2019, 04:39:31 pm »
Yes those are 1000 Ohm resistors, and 4000 Ohms isn't standard.
Since these are 5% tolerance, a 3900 Ohm resistor should suffice for replacement.
Still, it depends on what you are doing. If those resistors have been selected then you may want to select their replacement as well. If your 3900 Ohm substitute turns out to be a bit too low, then increase it by adding a small series resistance. However it seems you want to reduce the number of parts so you could get a batch of 3900 Ohm units and select from those.
Logged
krayvonk
SM3VLC
Newbie
Country:
Reply #8 on:
July 13, 2019, 11:25:18 pm »
Don't forget to take power dissipation into account.
if those 1k are in parallel and you replace them with only one, you might need a resistor that can handle up to four times as much power.
Logged
krayvonk
bob91343
Super Contributor
Country:
Reply #9 on:
July 14, 2019, 01:56:24 am »
You would need 23 Volts or so across a 1000 Ohm resistor to dissipate one-half Watt.
Logged
krayvonk
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
