I am unsure of the other answers too - You can still put uA in to 120/240VAC, right?
A novel measurement. I took out my ExTech 210 and measured the resistance across uA mode, however that only appeared to give ~100 ohms. I had to while it was on or it was open loop, so I'll scratch that for now.
I then thought of shunt resistors in general, would they be the same values for each range? I'd say generally you'd want them to be low for high current (fuses are a must... 120VAC/0.1 ohms =...1.2kA!), however in mA and uA mode...You may approach the kilo and megohm ranges...
Dave's uCurrent adapter seems to not (10 ohms for uA?), but his goal was to lower burden voltage. A few kohms may keep things safe though in yours.
Heh, free bit of learning either way for me.
Alexander.
