Its quite likely your 12pf will only be around 10pF anyway will be fine, I am curious as to why you need external osc / xtal with PIC24 ?
I need an external osc because i'm using the usb module.
Quote from: exapod on May 16, 2014, 09:45:34 pmI need an external osc because i'm using the usb module.Are you sure it works with a 16 MHz crystal for that? I've no experience with that PIC model but considering USB is 48 MHz, I would have expected that you would want a 6/12/24 MHz crystal, just to make the PLL a little easier. Maybe it doesn't matter.
