Well, me, with my absolute just basic skills is trying to figure out why my old man's LCD monitor stopped working..
The monitor is all black, no life at all, so I suspect the power supply... after some measuring, some googleing I now think the fault is in the inverter, wich is a full bridge inverter board, there is a total of 4 small IC's, that is connected to some high voltage transformers, the pcb around these IC's is miss coloured, may been some excessive heat going on...
I think (I may be totally off here..
) the IC's are some sort of powertrench mostef's, but I can't find any info about them, the number is P600 AD2T13.. I don't like to put my probes on the pins before I know what's what...
Anybody know of the P600 AD2T13
