Author Topic: Older green resisters.  (Read 508 times)
Offline Hammer_651Topic starter
« on: September 29, 2024, 06:31:52 am »
 Hi all. Can anyone tell me what type of resistors are in this PCB from a 1980 Multi-meter please. They have size but not sure of wattage.
Thanks.
H.
Offline madires
  • A qualified hobbyist ;)
Re: Older green resisters.
« Reply #1 on: September 29, 2024, 11:37:59 am »
The greenish grey ones should be film resistors. No idea if carbon or metal film. I'd guess, the smaller ones are 0.25W and the larger 0.5 or 1W.
Offline Gyro
« Reply #2 on: September 29, 2024, 11:46:49 am »
My guess would be that, with very specific values like 140.6k, they are metal film. Unless broken, leave them as they are.
Best Regards, Chris
Offline Paul T
  • Mechanical Integrity Engineer
« Reply #3 on: September 29, 2024, 09:02:39 pm »
Looks like older German-manufacture resistors marked with the older DIN standard for ohms as "D".
Perhaps the PCB and solder joints need more attention than the resistors?
Electronics always a core hobby. Sometimes I blog at KeepOnTesting.
Offline TimFox
« Reply #4 on: September 29, 2024, 09:05:24 pm »
I think that the "D" indicates tolerance, not ohms.
Probably 0.5%.
The following users thanked this post: I wanted a rude username
Offline Paul T
« Reply #5 on: September 29, 2024, 10:28:29 pm »
You’re right.
Offline Poroit
« Reply #6 on: September 30, 2024, 07:39:12 am »
G'day Hammer,
What switch ranges are these resistors associated with in your Multimeter?
