Author Topic: PCB holder; what are you using?  (Read 60739 times)
Offline Short Circuit
Re: PCB holder; what are you using?
« Reply #25 on: April 19, 2012, 07:00:48 am »
This is ok for my use at the moment.
Terrible for most practical uses. With one exception; these are quite convenient for holding an oscilloscope probe on your pcb.
Offline Mint.
  • Account is inactive now. Thanks everybody!
    • Personal Blog, Mint Electronics.
« Reply #26 on: April 19, 2012, 07:04:36 am »
Agreed :D
Personal Blog (Not Active Anymore), Mint Electronics:
http://mintelectronics.wordpress.com/
Offline shebu18
« Reply #27 on: April 19, 2012, 08:49:24 am »
As i sad, for the moment they are ok for what i need. I do not have big PCB's and the hold them well untill i put the smd component on top.
Offline T4P
  • Country: sg
    • T4P
« Reply #28 on: April 19, 2012, 02:46:27 pm »
Actually those third hand things are hopeless even with smaller pcbs , they just bend over .
*With a quite big a pcb that 6 pound thing (i have it) actually can tip over*
Third hands are only good for holding probes and wires .
Offline krenzo
« Reply #29 on: April 19, 2012, 08:13:34 pm »
I bought this one: http://www.amazon.com/gp/product/B003WNY83M/ref=oh_details_o01_s00_i00
It works better than the other horrible helping hands.  It's not perfect, but it's much more flexible and has a table clamp so that it doesn't fall over.
I see some people are posting vices that have the vacuum seal on the bottom.  How long does your seal hold?  I bought one, but the vacuum seal will only hold for about 30-60 seconds on mine.
Edit:  Looks like the issue with my Panavise is my workbench's surface is porous and letting air in.
« Last Edit: April 21, 2012, 03:17:57 am by krenzo »
Offline MikeK
« Reply #30 on: April 19, 2012, 09:28:25 pm »
A Panavise is good (I use one), but you need the 376 head to hold 8" boards.
Offline T4P
  • Country: sg
    • T4P
« Reply #31 on: April 20, 2012, 09:58:36 am »
Edit:  Looks like the issue with my Panvise is my workbench's surface is porous and letting air in.
hah ! yeah , mine wouldn't work at all on my glass table . No lacquered surface to test on . ( Er , it ain't panavise )
Offline G7PSK
  • It is hot until proved not.
« Reply #32 on: April 20, 2012, 08:40:18 pm »
I just use a sand bag to place things on, it deforms to shape.
Offline HooRideTopic starter
« Reply #33 on: April 22, 2012, 06:14:42 pm »
Good to know about the panavise 376, that looks like a good one too. I'll see how my Weller holder works out for me.
I like your idea G7PSK; inexpensive too!
Please enter all complaints legibly in this space -> [  ]
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #34 on: May 23, 2012, 08:46:24 pm »
Just some insights on this view, using mostly SMT you likely don't need a PCB holder for assembly, particular without any components that keep the PCB from lying flat, which is preferred in SMT components.  If you plan assembly to leave tall items to the end, big items like transformers or electrolytics can actually be the platform, balanced against say a prop piece of wood or the dreaded helping hands!  ;)   Free_electron mentioned using 'silly putty' as a prop, and that has an added value of being sticky without leaving a residue.
However, in troubleshooting, modding, hacking, removing or salvaging parts, a PCB holder of some kind is very helpful, particularly with through hole parts.  Through hole also means making jumper connections, removing or adding headers, etc., A question then becomes which design offers the most utility, at lowest cost.  I like Panavise because its been around forever, and you can get parts anywhere including used at eBay or swap meets for far cheaper than new.
So in the end, PCB holders I think aren't "useless", as the word implies of no value, but more "used-less" than you expect, given smaller PCB sizes and lower parts count and SMT components.
I find however, that most of what I do is modify rather than build from the ground up.  When I build, its dead bug style and a PCB holder is very helpful when it comes time to etch out the copper with a dremel tool to hold the PCB from dancing about, and keeping both hands free for the fine work.
A simple test is try to assemble without holder.  If you find yourself using a hand to keep positioning the board in any angle but flat, or holding it down, you probably can use a holder.  The cheapest one that can work is the controversial helping hand, and keeps you from spending too much for something that may be 'used' less than you expected.  If you find you keep fidgeting the helping hand while you're doing the work, you either don't have the best position possible for it, or you need something better.
these 'pcb holders' are useless.
While his tone may not be exactly avuncular, his point is valid.  Those things *are* pretty much useless...
« Last Edit: May 23, 2012, 08:48:48 pm by saturation »
Best Wishes,
 Saturation
Offline StubbornGreek
« Reply #35 on: May 23, 2012, 10:01:56 pm »
Funny, I just started a thread on this here:
https://www.eevblog.com/forum/beginners/better-than-%28un%29helpful-hands/
Here's a quick shot:
"The reward of a thing well done is to have it done"
-Ralph Waldo Emerson
Offline CyberWalker
  • Country: gr
  • Courage doesn't always roar.
« Reply #36 on: May 24, 2012, 10:43:30 am »
I wish to buy a PCB holder, too! I was searching the other day on mostly ebay and I came around some decent designs...  But still, the best of them seem to be somewhat heavy and the shipping costs included become prohibitive... I think that StubbornGreek has a good design idea!  :D
I've been messing with hardware ever since I can remember myself... I always loved hacking the science out of stuff but it was not until the age of 14 that I could proudly present something useful out of it! ;-)
I love technology and anything that includes a sophisticated concept or design! :-)
Offline meerweten
    • Greendigit Electronics
« Reply #37 on: May 24, 2012, 02:03:35 pm »
i don't use one, i just use my desk and a woonden bar i placed on it to hold it steady
Meerweten, Want meten is Weten
Offline jaspel
« Reply #38 on: May 25, 2012, 07:24:55 am »
For smaller boards, I find a drill press vice to work great.  Just don't over tighten it.
Offline DJKA
  • Country: lt
    • PlusFM!
« Reply #39 on: May 25, 2012, 09:14:47 am »
I use "improved" helping hands ;)
http://ikelk.lt/images/2c0b404511
« Last Edit: May 25, 2012, 09:18:40 am by DJKA »
DJKA
Offline aluck
  • Country: ru
« Reply #40 on: May 25, 2012, 05:29:54 pm »
Same thing with mine. No table or workbench is going to be perfectly flat and clean forever.
Will pour 2-4 pounds (1-2 kilos) of lead into the bottom of my vice. No, seriously. Think it's a good idea.
Offline updatelee
« Reply #41 on: May 26, 2012, 01:53:09 am »
I have the panavise 315 and 305 bought on the basis of all the great reviews of panavise.
Id never buy another panavise product again, pure junk. poorly designed almost all cost parts with ruff edges and extremely poor fit and finnish. I rarely use mine because is such a pia and pos. Very poor workmanship and metal, Ive seen better products produced in China.
Offline jhalar
« Reply #42 on: May 26, 2012, 07:17:11 am »
I use an old Goot ST-10 PCB holder that I had for about 20 years.
An oldie but a goodie. Works for me.
Electronics and Network Engineer. Working in both worlds.
Offline Bored@Work
« Reply #43 on: May 26, 2012, 07:59:27 am »
Are you sure you got an original one, and not a counterfeit?
« Reply #44 on: May 26, 2012, 08:09:20 pm »
I should have posted sooner... here is what I bought, works great! Weller ESF120 as suggested by Spawn. Fun to see if any of you can guess what that board is!
« Reply #45 on: May 26, 2012, 08:20:00 pm »
Game console of some sort, made in the 1980's. Looks like you are replacing one of the game controller sockets, they were rather prone to breaking, after heavy use.
Offline jhalar
« Reply #46 on: May 27, 2012, 08:49:45 am »
I'm not sure but the feeling I get is of an Atari 2600 games console.
Offline 0xdeadbeef
« Reply #47 on: May 27, 2012, 09:01:28 am »
This look interesting at least for hot air stuff and it's rather cheap - not for big PCBs though (15x12cm)
AOYUE-326 PCB working platform
Offline codeboy2k
« Reply #48 on: May 27, 2012, 09:33:17 am »
Those triangular endcaps, knurled knobs and board grips all look printable with Dave's new Makerbot... :)
I don't own a Makerbot or anything like it, but if I did... I'd be printing now, and putting it together with threaded rod from the hardware store.
Offline saturation
    • NIST
« Reply #49 on: May 30, 2012, 08:59:31 pm »
It looks suspiciously like an Atari 2600 PCB.
Best Wishes,
 Saturation
