Author Topic: Potential divider cct Vs Regulator/ buck converters etc  (Read 2819 times)
Offline johndon2000Topic starter
« on: June 13, 2013, 11:27:52 am »
Am I correct in thinking it is feasible to use a potential divider circuit to convert a 12V power supply to 5V, but it is just not practical?
And the reasons its not practical is because it's not efficient, excessive heat loss, melting resitors etc & there are much better alternatives (regulators, buck converters etc)
alm
  • Guest
Re: Potential divider cct Vs Regulator/ buck converters etc
« Reply #1 on: June 13, 2013, 11:40:38 am »
The current you draw from a voltage divider should be small compared to the quiescent current. If you want to draw 1 A from a voltage divider that divides 10 V down to 5 V, then you might want the quiescent current an order of magnitude higher, so 10 A for example. This divider will consist of two 0.5 ohm resistors. Drawing 1 A through these resistors will reduce the voltage to 4.5 V instead of 5 V due to loading (bad load regulation), and in the mean time you will convert 50-60 W to heat in each of the resistors, even when not drawing any power. A linear regulator will be an order of magnitude more efficient under load, and maybe four orders of magnitude when idle, and a buck converter might be two order of magnitude more efficient under load.
For tiny currents, like the base current of a small signal transistor, the current drawn from the divider is negligible, so you can use much larger value resistors. This is where voltage dividers are commonly used.
Offline digsys
    • DIGSYS
« Reply #2 on: June 13, 2013, 01:05:31 pm »
Also, IF for some reason you didn't want to use a regulator, and only needed say up to 10mA, you can make your resistive divider,
with say 0.1mA Q, and feed that straight into a Op-Amp Buffer (which can be as small as a SOT23-5).
« Reply #3 on: June 13, 2013, 01:54:50 pm »
ok thanks guys :)
so, in a nutshell, you would use a potential divider in low current (mA) applications, but for higher current you should use a regulator etc?
Thanks again!
Offline c4757p
  • adieu
« Reply #4 on: June 13, 2013, 02:03:10 pm »
As a rule of thumb, voltage dividers are used for signals, not power. (There are notable exceptions - hair dryers, for example, use the heating element as a voltage divider to get a lower voltage for the motor.) Even if a circuit uses less than a milliamp, it's quite rare to power it through a voltage divider. They can be used to configure a regulator, but the power isn't actually going through the voltage divider in that case.
Offline c4757p
  • adieu
« Reply #5 on: June 13, 2013, 02:07:14 pm »
At which point you have made a regulator...
Offline digsys
    • DIGSYS
« Reply #6 on: June 13, 2013, 10:50:55 pm »
Quote from: johndon2000
  so, in a nutshell, you would use a potential divider in low current (mA) applications ...
Not would, could. I added it as an example of what you COULD do, given that you had started with a Voltage divider example.
Quote from: c4757p
Some say Potatoe some say Potato ... :-)  .... see above
Offline c4757p
  • adieu
« Reply #7 on: June 13, 2013, 10:52:25 pm »
Perfect analogy - the ones who say "potato" are spelling it right...  ;)
