Unless you absolutely need the pad, use some wire:
Take some AWG 30 wire ,strip the end, using cyanoacrylate (super glue) , glue the insulation covered wire to the board leaving about 1 inch of the stripped end free.
After the glue has dried , solder the wire to end of the trace. If you don't glue the wire first the connection is so weak that it will likely break free if you move the wire. Some people use tape instead of glue, but I like the glue best.
