Author Topic: [SOLVED] P-Channel mosfet voltage loss between D-S  (Read 594 times)
Offline gmcTopic starter
« on: June 27, 2024, 10:16:18 am »
I'm busy with a project to switch 5V (0.5A) using a p-channel mosfet (NDP6020)  and it's kind of working although I'm getting a unexpected voltage drop across the D-S of the mosfet.
https://www.onsemi.com/pdf/datasheet/ndp6020p-d.pdf
The mosfet is being driven by a NPN transistor and I'm using a 3.3V atmega88 microcontroller to switch the mosfet on/off
With the output of the Atmega88 at 3.3V this turns on Q2 which puts the voltage of gate of the mosfet  low enough to turn it on.
I would expect 4.98V at the drain. I though it might be as there was no load on the drain but have added in a 1k resistor from drain to GND and still seeing 4.63V
Clearly there is some issue with the circuit or my understanding of mosfet is wrong.
I've taken voltage readings and added them to the schematic.
Where am I going wrong?
« Last Edit: June 27, 2024, 02:28:29 pm by gmc »
Offline Phil1977
Re: P-Channel mosfet voltage loss between D-S
« Reply #1 on: June 27, 2024, 01:25:09 pm »
Did I read it right you loaded the FET with 1Ohm? Then around 5A I_DS are expected, and a voltage drop of 350mV with a RDS_on of 50mOhm + some mOhm of PCB/solder/voltage source resistance seems not unplausible.
Can you measure the I_DS?
« Reply #2 on: June 27, 2024, 01:28:58 pm »
Sorry, correction. loaded with a 1k resistor.
Offline Phil1977
« Reply #3 on: June 27, 2024, 01:33:56 pm »
Did you incidentally swap S and D? Is the switching working in general?
« Reply #4 on: June 27, 2024, 01:45:33 pm »
I've rechecked and orientation is correct, but it's not switching off either :(
Tried swapping the mosfet - same issue.
Have updated the schematic with voltages when the output the uC is LOW.
Offline HwAoRrDk
« Reply #5 on: June 27, 2024, 01:49:39 pm »
Are you absolutely, positively sure you haven't got the MOSFET the wrong way round? A voltage drop of 0.35V sounds like what you might see for the VF of the body diode passing current. Especially if it "won't turn off".
« Reply #6 on: June 27, 2024, 01:55:34 pm »
100% sure.  Rechecked footprint and soldered in the right way.
Unless I've got some dodgy mosfets but i have tested them with a component tester and the pinouts match.
« Last Edit: June 27, 2024, 01:58:11 pm by gmc »
Offline Phil1977
« Reply #7 on: June 27, 2024, 01:58:40 pm »
Do you have a transistor tester?
Many MOSFETs from dubious sources are fake, sometimes they just relabel anything in a TO220-housing.
« Reply #8 on: June 27, 2024, 02:06:51 pm »
Transistor tester passes and matches the footprint.
Online wraper
  • Country: lv
« Reply #9 on: June 27, 2024, 02:08:58 pm »
NDP6020 is N-channel and you tester shows that too https://www.farnell.com/datasheets/59594.pdf, NDP6020P is P-channel. Also this is an obsolete part which you should not buy for anything other than repairs, still I would get something different for that as you'll likely get fakes from places where they are available.
« Last Edit: June 27, 2024, 02:30:10 pm by wraper »
« Reply #10 on: June 27, 2024, 02:14:46 pm »
Aaggghhh. How many mistakes can I make on this project :(
It's supposed to be a P-channel but during my search for a mosfet I select N-channel instead.
Will look into making some hardware hack to use a N-channel (Or probably better just buy the correct mosfet)
Online wraper
  • Country: lv
« Reply #11 on: June 27, 2024, 02:17:22 pm »
N-channel won't work without about 8V or higher supply to drive its gate unless you put it on the low side.
« Last Edit: June 27, 2024, 02:19:17 pm by wraper »
« Reply #12 on: June 27, 2024, 02:19:37 pm »
Scratch the above.  Another doh moment.
I bought a NDP6020P (So at least I'm not losing my mind) which as you said should be  a p-channel mosfet.
It's testing as a N-channel so I've been sold a fake as you suggested :(
Online wraper
  • Country: lv
« Reply #13 on: June 27, 2024, 02:22:47 pm »
What's actually written on the part? I see listings on aliexpress use both part numbers in the title. It's very rare that suffix means different channel type, so easy to get confused even for experienced engineer.
« Reply #14 on: June 27, 2024, 02:25:34 pm »
NDP6020P
Online wraper
  • Country: lv
« Reply #15 on: June 27, 2024, 02:26:33 pm »
Then must be fake, counterfeiters looked in the wrong datasheet  :-DD
The following users thanked this post: gmc
« Reply #16 on: June 27, 2024, 02:28:08 pm »
Thanks for the help. At least that explains it.  Will source a more modern part while from a better source now.
Offline Phil1977
Re: [SOLVED] P-Channel mosfet voltage loss between D-S
« Reply #17 on: June 27, 2024, 02:38:03 pm »
Or the P-type is 1cent more expensive... This way the component will at least not work from the beginning instead of failing during usage.
People who organize this should get circumcised with the solder iron.
