Author Topic: Lengthening hot air hose?  (Read 584 times)
Offline u666saTopic starter
  • Country: ru
« on: September 06, 2023, 06:32:13 pm »
Anyone done it? My station is 2703A+. With microscope I need to hold it with my left hand and blow from the left, and work with scizors with my right hand. Station is on the right. Put it on the left? Then I'd get situation where I'd need to lengthen solder iron wire so I can work with my right hand.
Where would I get the hose? I looked all over ali, nothing there.
Offline gjvdheiden
Re: Lengthening hot air hose?
« Reply #1 on: September 08, 2023, 04:27:05 pm »
Not me, but this YouTuber MendItMark did:
To the point for your question at timestamp 10:08.
He's capable of repairing all sorts of stuff.
His desolderingstation is quite a beast too.
Offline JustMeHere
« Reply #2 on: September 08, 2023, 04:52:27 pm »
Why not use paste?  I only use paste with my hot air.
Online BrokenYugo
« Reply #3 on: September 08, 2023, 05:55:59 pm »
Much simpler to lengthen the iron's cable since it uses a standard connector you can just buy a mating pair of and terminate onto a suitable cable or wire bundle.
