Maybe the -3.3V is discharging too quickly. Im curious about the CV loop's stability?The design that I like, doesn't need a negative control rail, https://www.eevblog.com/forum/beginners/lm324-power-supply-with-variable-voltage-and-current/msg3582664/#msg3582664
