Just poking around with my oscope and can't figure out what I'm measuring here off the positive LED leg. The circuit is open; negative battery terminal is off the board and the cap is pulled. Still showing a reading on the scope and I can't explain why. Shouldn't it be showing a flat line?
M[/s]Hz
Idk man, I'm still trying to figure it out. I can replace stuff that's clearly burnt out or suck up solder that's bridging IC pins but that's about it atm.
