Author Topic: Infrared vs Hot Air for Rework Stations  (Read 3619 times)
Offline requimTopic starter
« on: January 03, 2012, 07:01:48 pm »
It seems as if the higher end rework stations all use infrared instead of hot air.  What are the advantages/disadvantages of using infrared instead of hot air? I assume one advantage is that infrared can be focused more tightly.  Anything else?
alm
  • Guest
Re: Infrared vs Hot Air for Rework Stations
« Reply #1 on: January 03, 2012, 09:22:38 pm »
Not blowing small parts away appears to be a convenient advantage.
Offline xygor
« Reply #2 on: January 03, 2012, 10:17:59 pm »
Infrared doesn't work too well on shiny things.
It's more difficult to get accurate temperature with infrared.
« Reply #3 on: January 04, 2012, 12:30:35 am »
I would agree, however I've never had any problems with parts blowing away or shifting while using a heat gun.
