The problem is the extra CC pins on USB-C that inform the device about how to handle what was just plugged in.
These modern small laptops use the USB-C for both charging and to connect devices, so the port has to know if it has to receive power or give out power, if so at what voltage. They also tell it to interrupt the power when the cable is pulled out, since at the higher power levels this could draw an arc and damage the connector.
USB-A does not have these extra pins so 5V power is always presented by the host. So a USB-A to USB-C cable will provide power even when the USB-C end is not plugged into anything. However on a USB-C to USB-C cable these pins are wired directly between both ends. In the case of a USB-C to female USB-A adapter cable, the appropriate resistors are built into the cable, this tells the host machines USB-C port "Please act like a USB host and provide 5V power".
So now the device on the other end has to present the correct signals/pullups/pulldowns in order to tell the host to provide power. So there are some badly designed devices out there that just use a USB-C connector as a direct replacement for a microUSB, only connecting the regular USB 2.0 pins.
