As this is the first electronics test gear which will be coming in the office I am not sure what budget will be passed so i will ask you give two options mid-range one and low-end one.
Still, money does matter, what ever features or capabilities of the scope, all talks and discussions will be useless as people don't have any idea what those mid and low end level translate into dollars.
A US $1000 probably means nothing at developed country if its for business, but in India, does US $1000 fall into mid or low ?
As you set your flag from India, even you have found the ideal scope, will it be easily bought in India ? Does it have authorized distributor, as this will be used for business, warranty is important, unless your boss has other idea that your company can afford to buy an "Aliexpress" type scope deal that came with shady warranty ?
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Now, back to "money" talk, even at the end of discussion, you've found the ideal scope, and the "budget", but will that number still applicable at India ? As I'm aware, these kind of electronic stuff has heavy import tax there, also the mark-up price by distributors will be high too as the market is quite small there.
You need to give the hard number, other wise all of this is just useless chit-chat.
My 1/4 watt resistor worth of advice.
