Hello. I'm new to oscilloscopes but interested to learn. My current goal is to use a Hantek 5072P to capture two separate single events: a) charging and b) discharging a capacitor in an RC circuit. This seems like it should not be hard. But so far I have been unable to capture these wave forms. I hope someone with experience using this scope might be able to see what I'm doing wrong.
For guidance, I am using the Hantek DSO5000P Series User Manual (Version 1.1).
Section 6.4 Example 4 reads:
Capturing Single-shot Signal
You may refer to the following example to easily capture some aperiodic signals like pulses and
glitches. To set for a single-shot acquisition, follow the steps below.
1. First, set up the oscilloscope probe and the attenuation factor of CH1.
2. Turn the vertical VOLTS/DIV and horizontal SEC/DIV knobs to a proper position for a better examination of the signal.
3. Press the ACQUIRE button to see the Acquire menu.
4. Push the Peak Detect option button.
5. Push the TRIG MENU button and select Rising for the Slope option. Then adjust the trigger level properly.
6. Push the SINGLE SEQ button to start the acquisition.
I understand in general what each setting on the relevant menus aims to do but no doubt subtleties are lost on me. Using this recipe I have been able to capture a single instance of the scope's own 5V square wave calibration signal. I cannot understand why I have not been able to capture the RC circuit wave forms.
The RC circuit is constructed on a breadboard using 100nF cap and 1k resistor connected to variable DC power supply set to 3V. I have a push button switch connected across the capacitor to discharge. I can see with a multimeter that the circuit behaves as expected: with power supply on the capacitor shows ~3V. When the switch is closed the voltage across the cap drops to ~0V, when open it returns to ~3V.
With the 10x probe on CH1 of the scope connected to the positive side of the cap and the ground clip connected to the circuit ground, I can see a trace showing constant 3V when the scope is in Auto mode. My understanding is that for this circuit tau = RC = 100 x 10^-9 * 1000 = 10^-4 = 0.1ms = 100us and I have the horizontal time base of the scope set to 80us so that the charging event should take approximately 5 * tau = 500us = ~6 horizontal divisions to complete.
On the Acquire menu I have tried Normal and Peak detection modes with DC Coupling.
On the Trigger menu I have tried a) rising edge in either Auto or Normal modes. b) slope detection with a trigger value of +1V over 100us (a voltage which should be exceed during the first time-constant interval).
Any insight appreciated. Thanks!
