Author Topic: How to get started agian in circuit design?  (Read 1207 times)
Offline richardnhoffmanTopic starter
    • Personal CV site
« on: January 28, 2017, 01:36:37 am »
Hello everyone,
I am a recent graduate from DeVry University in Decatur,Ga with a Bachelors and Cum Laude in Electrical/Electronics engineering (BEET). Not too long ago I just rebuilt my little lab I have at home and have been restoring a few electronics as well as just built an Elenco M-1250k for work. Since I have started working at Hartsfield Jackson on the Plane Train it has been quite some time since I have practiced any electronic work. I was wondering what books, resources, and materials can I get to help me get back into circuit design as well as learn about multiple components of today as well as today's micro-controllers? (I know Arduino and HSC12 but not other markets)
Thank you for the help in this matter.
I will say this - and I'm gonna say it on tape so everybody hears it a hundred times a day: If I die before you people can pour me into a computer, I want Caroline to run this place." - Cave Johnson
Offline rstofer
Re: How to get started agian in circuit design?
« Reply #1 on: January 28, 2017, 03:08:07 am »
On the microprocessor front, the Arduino is a great place to start but..  It's still a slow Arduino.
The next step up is probably one of the ARM 32 bit processors and there's a bunch.  Around here, the ST32Fxxx development boards are very popular.  Were it me, I would start with the MBED original LPC1768 'stamp' type board.  These are easy to breadboard, there are MANY complete libraries and there is no toolchain to install because you can do all the code development via the Compiler web site.  I like this platform because I can plug it into a breadboard and because it is FAST.  Pinout is limited, of course, but has proven adequate for my projects.  Still I have several ST32Fxxx board.
https://developer.mbed.org/platforms/
Some of the ST32F boards are also supported by the mbed tools.  The degree of support is often far less than for the legacy LPC1768
Op amps:  Dave has a couple of videos and the Internet is full of information.
Circuit design (the math part):  Try "Real Analog" at https://learn.digilentinc.com/classroom/realanalog/  This will refresh your skills and probably bring along some new information.
FPGAs:  There is another program at Digilent oriented toward FPGAs.  There is information all over the Internet.
Transistor design:  Not so common anymore.  The "Real Analog" course will really help when you start trying to analyze transistorized circuits.
Good luck!
Offline danadak
« Reply #2 on: January 28, 2017, 12:16:42 pm »
Consider Cypress PSOC, for the following reasons -
For me what stands out is -
1) Routability
2) Fast 12 bit SAR A/D and slow 20 bit DelSig
3) DFB (Digital Filter Block) that is dual channel, handle FIR or IIR filters, or DFB
can be used as a GP fast processor block, similar to RISC block
4) MSI logic elements GUI based and/or the UDB Verilog capability. Eg. the FPGA
like capability
5) Onboard Vref
6) IDAC, VDAC, OpAmps (up to 4), comparator, mixer, switch cap, analog mux....
7) LCD,  COM, UART, I2C, I2S, One Wire, SPI, Parallel, LIN, CAN, BLE, USB
9) Custom components capability, create with schematic capture or Verilog
10) DMA to offload processes like filters, COM, Display
11) ARM M0 (PSOC 4) or M3 (PSOC  5LP) or 8051 core(PSOC 3)
12) Extensive clock generation capabilities
13) All components supported by extensive prewritten APIs
https://www.element14.com/community/thread/23736/l/100-projects-in-100-days?displayFullThread=true
http://www.cypress.com/documentation/code-examples/psoc-345-code-examples
Great video library
Attached component list.  A component is an on chip HW resource.
Free GUI design tool with schematic capture, "Creator". Components have rich API library attached
to each component. Compilers free as well.
PSOC 4 is low end of family, consider 5LP parts as well. PSOC 4 also has arduino footprint boards (pioneer) as well
https://www.elektormagazine.com/labs/robot-build-with-cypress-psoc
http://www.cypress.com/products/32-bit-arm-cortex-m-psoc
Regards, Dana.
