A replacement with a foil capacitor usually works, if there is enough space. I would look for MKS type as that is often the smallest size and the electrolytic capacitor anyway has poor DA and series resistor. So no need for a low loss cap like PP. For this special type one may have to look for sufficient riplle current rating, which may exclude the smallest form factor.
I agree with JZX: a bad part in the defelction circuit would cause a geometry problem / image distortion, but not an intensity problem.
The shaddow following a sharp contrast is more a thing of signal reflection. A classical case was a problem (impedance mismatch and thus reflection) in the antenna cable. If this is with a PAL signal, it could in theory be the delay line, though this should be more a color issue than.
If it is blur in all directions, is a problem of the focusing circuit (high voltage).
If it is only blur in horizontal direction (ie, horizontal stripes are well defined but not vertical lines), is a problem of the path of video, loss of bandwidth.
Blur screen usually appears when I plug ac cable and as soon as switch it on, and This Blur screen usually only last 3-7 minutes, After that It displays normal not blur screen at all.
I confirmed that It only blur in horizontal direction(it has even more terrible shadow following a sharp contrast than a picture which I uploaded to dropbox yesterday)
It seems that there is cold soldering in the path of RGB connection.
Then Should I resolder any components which is close to RGB pin of TB1231N and any components which lies in the trace of RGB connector in CPT board?
I repaired 29 inch CRT TV,BUT...I noticed that There is always overlapping white gradient letter like below link.
https://www.dropbox.com/scl/fi/oxtwbrt824k8s7hz4rf55/20240716_224510.jpg?rlkey=zslga97y32kba1yhi73xubhd6&st=2em23akf&dl=0
I found that a bi-polar capacitor(C433 SAMWHA NF series 5.6uf 50v), which is next to Q408 KTD2059-Y transistor and close to AN5521 IC in the attached schematic(lg_chassis_mc-7ca_sch pdf file),actually has large capacitance(10uf).
https://2.imimg.com/data2/SD/JD/MY-/samwha-catalogue.pdf
I think that this problem(overlapping white gradient letter) has something to do with out of capacitance tolerence of this bi-polar capacitor.So I want to replace this NF series capacitor.
But it is impossible to find bi-polar capacitor which has 5.6uf specification.
Luckily,I found that I can purchase ECW-F2565JA from where I live.
https://www.eleparts.co.kr/goods/view?no=10864147
By the way,Is it impossible replace bi-polar capacitor with film capacitor?
Why don't you test the old cap?
As It seems that old bi-polar cap(C433 SAMWHA NF series 5.6uf 50v) only affect on vertical direction,and It seems that there is no defect in vertical direction, So I take advice to not replace old bi-polar cap with film capacitor
