Author Topic: Opamp inputting to microcontroller  (Read 4834 times)
Offline FaringdonTopic starter
« on: September 05, 2023, 05:46:05 am »
We have an opamp buffer which has Vcc of -3v to 20v. Its non-inv input is always positive.
Its output  connects directly (no series resistor) to a micro pin, whose rail is 0v to 3v3.
Is there any chance, during startup, or whatever, that the opamp could output the negative rail into the micro pin?
'Perfection' is the enemy of 'perfectly satisfactory'
Offline djsb
Re: Opamp inputting to microcontroller
« Reply #1 on: September 05, 2023, 06:03:26 am »
Test it on a breadboard and find out for yourself.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
The following users thanked this post: Faringdon
Offline Gyro
« Reply #2 on: September 05, 2023, 11:25:21 am »
Troll Treez question! What kind of idiot would feed the output of a -3V/+20V supply opamp into a 3V3 micro input with no current limiting!
Best Regards, Chris
Offline Doctorandus_P
« Reply #3 on: September 05, 2023, 12:22:29 pm »
This would indeed be quite silly to do. You risk SCR latchup of your microcontroller or other nasty things.
But the question is still good to ask though, and the answer is simple: Just don't do it, even when it seems to work while testing on your bench.
There are application notes for mains voltage zero crossing detection with a microcontroller by just connecting a series resistor to a microcontroller pin (Watch it's voltage rating). Microchip did this 20 to 30 years ago. Atmel followed 10+ years later, and now they are one company again. Other uC manufacturers may have similar application notes.
uC datasheets are very sparse about specification of the internal ESD protection. I have seen one reference that wrote that a 2mA (DC) injection current into an I/O pin is safe. From another manufacturer I once saw 4mA specified. Some datasheets also specify a maximum current for which SCR latchup is guaranteed to not occur, but those specifications are probably for a short current burst (which is probably good enough for you).
Offline tggzzz
« Reply #4 on: September 05, 2023, 12:41:31 pm »
Another asinine Faringdon/Treez question. What a surprise!
For a start he couldn't even be bothered to phrase the first sentence in an unambiguous way. So the "Vcc is -3v to 20v". What's the opamp's other supply pin's voltage range?
Then he couldn't even be bothered to define the circuit. So what if the non-inv pin is always positive? That's only a small part of the necessary information.
Finally he couldn't be bothered to define the opamp or micro. Details matter.
And he couldn't even be bothered to try it himself.
The following users thanked this post: Kean, tooki, golden_labels, Faringdon
Offline tggzzz
« Reply #5 on: September 05, 2023, 12:51:56 pm »
Would you agreeTM that it is a strange question from a professional engineer with several decades experience in many companies?
Would you agreeTM that it is strange to post the question in the "Beginners" section?
The following users thanked this post: David Aurora, Kean, tooki, Faringdon
Online langwadt
« Reply #6 on: September 05, 2023, 01:00:44 pm »
quite few ICs fpga/mcu/logic used to specify several mA in both directions via the ESD diodes, but now many MCU have 5V tolerant input have zener like ESD protection and specify that you are not allowed to inject current
« Reply #7 on: September 05, 2023, 07:25:10 pm »
Thanks, its as in the attached......to see what is the situation that could cause the negative output into the micro?
LTspice and jpeg attached.
I guess its deemed that noise at startup will make inv greater then non-inv and itll go output to the negative rail?...the actual opamp is the Texas one....TL084C...not the LT1006
« Last Edit: September 06, 2023, 06:48:44 am by Faringdon »
Offline magic
« Reply #8 on: September 05, 2023, 08:23:08 pm »
There is only one right answer:
Omitting that resistor will still not make your product cheaper than those imported from China, so do it right :box:
Knowing TL084, its output may very well shoot up to +20V if the negative rail is too slow to start or dead altogether.
Offline Manul
  • Country: lt
« Reply #9 on: September 05, 2023, 08:40:00 pm »
If V2 is PWM, can I ask why you deside to use op amp in the first place? If the signal is binary in it's nature, I don't see a point to use linear components, especially if it's just a buffer. Or are you feeding that PWM into the ADC for some reason?
« Reply #10 on: September 05, 2023, 09:02:43 pm »
Thanks, yes its into the ADC....
TL084C opamp
https://www.ti.com/product/TL084
STM32F103V micro (100pin)
https://www.st.com/resource/en/datasheet/stm32f103c8.pdf
The opamp goes into pin 35 of the micro which is labelled as an Analog input. ("PB0/ ADC_IN8 /T3_C3")
Opamps max output current is 26mA....maybe micro can survive it for a little bit?
Offline Manul
  • Country: lt
« Reply #11 on: September 05, 2023, 09:14:46 pm »
So why not add RC filter on the output? Resistor will limit DC current plus you have opportunity to low pass / anti-alias the signal a little bit.
Offline DavidAlfa
« Reply #12 on: September 05, 2023, 09:17:58 pm »
In first place: Why do you power the op-amp at +20v/-3v when it's going to feed a 3.3V device?
Why not just power it with 3.3V?
If the issue is reaching GND or VDD, use a rail-to-rail amp.
It this actually trolling? Feels like it.
« Last Edit: September 05, 2023, 10:13:42 pm by DavidAlfa »
Offline djsb
« Reply #13 on: September 05, 2023, 10:05:50 pm »
Very strange power supply setup.
No handling of any DC offset into MCU Analogue input.
Why would you feed a PWM signal (which is digital- A pulse that has its width modulated) into an Analogue input without low pass filtering?
WHERE IS THE LOW PASS FILTER?
As the dragons say, I'M OUT.
« Last Edit: September 06, 2023, 04:51:01 am by djsb »
Hertfordshire, UK
Offline ArdWar
  • Country: sc
« Reply #14 on: September 05, 2023, 10:25:54 pm »
Why can't you just use normal proven circuits in your designs like everyone else. Your ideas somehow never fail to draw a "what the fuck" reaction here. You need to either stop trying to reinvent the wheel, or maybe apply as application engineer in ADI or something serious.... ;D
If rail-to-rail is important, even a +5V supply is still infinitely safer. Most STM32 can tolerate 5V input to some extent if you limit the current. It's a specified operating mode in their datasheet. Although in my experience it may even survive without current limiting (don't intentionally do it in prod designs duh.)
Use a -0.3V negative rail or similar if you need the signal to swing to exactly zero. Something enough for the opamp output to slew into, but not enough to reverse bias whatever input structure on the uC.
Depending on how important the ADC accuracy is, a much better approach is to scale the ADC input into 0 - 2.048 V and use external 2.048 VREF. There's much less chance that a slight overdrive will mess the VDD rail, and especially AVDD.
Use actual resistor to limit the current, don't rely on output drive limitation alone. Make sure the resistor value is large enough to limit the current to safe value but not too large to affect sample and hold circuitry. STM32 datasheets specify maximum recommended RAIN values for specific sampling rate, look at it.
« Last Edit: September 05, 2023, 10:33:57 pm by ArdWar »
Offline floobydust
« Reply #15 on: September 06, 2023, 03:44:48 am »
Should we start a Go Fund Me to buy a reel of resistors for Treez Co. ?
MCU injection current rating is only 5mA, side effects include corrupting other A/D channel readings, amongst other problems.
Just as happy cross-posted thread: https://www.edaboard.com/threads/will-microcontroller-be-damaged-by-input-from-opamp.408262/
The following users thanked this post: tooki, Faringdon
Offline xavier60
« Reply #16 on: September 06, 2023, 05:34:33 am »
Forward biasing the microcontroller's input protection diodes by even a small amount, can cause a sort of crosstalk to other analog inputs.
Edit: just noticed it has been mentioned.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
« Reply #17 on: September 06, 2023, 05:51:00 am »
Thanks, its part of a quad opamp...some of them need the -3v and 20v.
« Reply #18 on: September 06, 2023, 05:53:02 am »
Thanks, micro needs to know when high and low, but also, if its "High enough".
A low pass filter wont be needed.....it just samples it every millisecond or so.....
..A low pass filter , is only needed if you have nyquist sampling rate issues...but we dont.
There is a school of thought that the opamp is a buffer...and that since its non-inv pin is never <0V, then neither should be the output.....though is there something with offset voltages of certain batches?...that when inv and non-inv are both 0V......it could be that non-inv "looks like" it is less than 0V?...so opamp output goes to negative rail?
Thankyou so much....that isnt the issue here, thanks anyway.
« Last Edit: September 06, 2023, 06:19:59 am by Faringdon »
Offline magic
« Reply #19 on: September 06, 2023, 06:08:49 am »
You have bigger things to worry about than offset :-DD
« Reply #20 on: September 06, 2023, 06:18:02 am »
Thanks, surely the offset is the main problem here...?..after all, its a buffer.....the + and - inputs should always be the same, and since + is always 0V or more...we should have nothing to worry about....since output should never be able to go negative......but the offset ......is whats screwing this up...i think?
Thanks, but we're not up against Nyquist,,,no need for filter here.
Thanks, Its one of a quad...and some need the +20v, -3v3 rails
« Last Edit: September 06, 2023, 06:22:46 am by Faringdon »
Offline xavier60
« Reply #21 on: September 06, 2023, 06:26:33 am »
From memory, up to -0.3V, maybe a bit more is allowed. Offset won't be anywhere near that.
Definately test for power up and power down glitches.
Edit: I would still add a resistor.
« Last Edit: September 06, 2023, 06:30:57 am by xavier60 »
Offline xavier60
« Reply #22 on: September 06, 2023, 07:10:52 am »
I had a close look at the schematic in post #7. All indicates that the opamp's output should always be in the range of 0V to 2.4V.
Offline liaifat85
  • Country: bd
« Reply #23 on: September 06, 2023, 11:01:32 am »
I think it's best to test with a multimeter.
Offline magic
« Reply #24 on: September 06, 2023, 01:05:28 pm »
It will be +19V before the -3.3V rail comes up ;)
Actually, about +4V >:D
