Author Topic: Finding a correct smd inductor for a macbook board  (Read 2009 times)
Offline adrkoTopic starter
  • Country: no
« on: February 09, 2021, 02:51:51 am »
Hello!
I'm having a lot of trouble finding replacement components - when I specify exact values on digikey, mouser and others - there is exactly zero results available.
My question is - which values don't have to be as precise? I'm only starting to understand how inductors work.
The values:
1.2UH-20%-0.12A-1.17OHM
component name in the schematics L5199
I'm attaching a screenshot for reference
Offline Jwillis
Re: Finding a correct smd inductor for a macbook board
« Reply #1 on: February 09, 2021, 03:35:02 am »
You can go a little higher value for inductance and current rating as long as the foot print (dimensions of the pads ) will fit the board . The resistance shouldn't change by much with a slightly different value .
The following users thanked this post: adrko
  • Country: no
« Reply #2 on: February 09, 2021, 08:18:53 am »
Hello
Thank you for the help, tried looking for components again but I'm having a lot of trouble finding proper component. If I kinda match the values parts are not on stock/obsolete. Not sure how high can I go with values
Offline kripton2035
« Last Edit: February 09, 2021, 08:28:01 am by kripton2035 »
  • Country: no
« Reply #4 on: February 09, 2021, 08:28:29 am »
Isn't the difference between 15mA and 120 mA bit too significant? Or am I simply getting it wrong?
  • Country: no
« Reply #5 on: February 09, 2021, 08:30:52 am »
The one from digikey is perfect, I also have a big order almost done in that store. But I'm afraid of making a mistake with using incorrect component and I don't fully understand inductor current values yet
Offline kripton2035
« Reply #6 on: February 09, 2021, 09:33:23 am »
re-sorry effectively 15mA will not work !
Offline kripton2035
« Reply #7 on: February 09, 2021, 09:37:34 am »
51 models available at octopart
https://octopart.com/search?category_id=4193&inductance=0.0000012&currentrating=%28120mA__%29&dcresistance_dcr_=%281__1.3%29
now you have to choose the good package, and something available.
Offline kripton2035
« Reply #8 on: February 09, 2021, 09:47:06 am »
this one from coilcraft seems also almost ok (1µH)
https://www.coilcraft.com/en-us/products/rf/ferrite-core-chip-inductors/0402-(1005)/0402df/0402df-102/
and you can get it as a sample ...
Online Zero999
  • 0999
« Reply #9 on: February 09, 2021, 11:44:58 am »
Why do you think the inductor is faulty? Is it obviously phsyically damaged? If not, it's highly unlikely to be faulty.
  • Country: no
« Reply #10 on: February 09, 2021, 04:02:34 pm »
I had a corrosion and a pretty big short and a burned connector on the circuit the inductor is a part of, just removed everything that did not look good, its usually dead simple to replace components, not this time though
  • Country: no
« Reply #11 on: February 09, 2021, 04:06:09 pm »
Wow! Thanks! Thats the stuff, I'm really grateful, you actually spend the time to find it for me, I'll try to get that one!
  • Country: no
« Reply #12 on: February 09, 2021, 04:14:27 pm »
Sadly the octopart shares the same problem as other websites, majority not in stock, most of them not even close to 0402 size, and I really don't feel like bothering a manufacturer directly to ask them to send me 10 or 100 inductors, I guess they'll just laugh at me
  • Country: no
« Reply #13 on: February 09, 2021, 04:22:40 pm »
When you mentioned octopart I remembered about this website I had in bookmarks(they have really good customer service btw)
https://lcsc.com/product-detail/presales_TDK-MLZ1005M1R0WT000_C531288.html
It looks like this one will do?
Offline kripton2035
« Reply #14 on: February 09, 2021, 05:48:45 pm »
looks like, but we don't know how much current the touchID needs. if it is 110mA this inductor will burn...
Offline mvs
« Reply #15 on: February 09, 2021, 06:36:46 pm »
Burn? MLZ1005M1R0WT000 is rated for 450mA with 20 °C temperature rise. At 110mA you just get some inductance loss due saturation.
Offline kripton2035
« Reply #16 on: February 09, 2021, 07:37:22 pm »
I see 100mA in the LSCS description ?
Offline mvs
« Reply #17 on: February 09, 2021, 09:47:19 pm »
100mA is just a number and unit. I you want to know their meaning, you need to look in the datasheet.
https://datasheet.lcsc.com/szlcsc/2003301511_TDK-MLZ1005MR47WT000_C502004.pdf
Manufacturers usually specify two current values in their datasheets. Isat is current for given core saturation (in this case max. 50%) and Itemp is current for given temperature rise (in this case 20 °C above ambient). On bigger inductors this values are usually much better matched together. But in this case you have Isat=100mA  and Itemp=450mA. This means, that you can apply 110mA of current to this inductor without overheating, but there will be large loss of inductance.
« Last Edit: February 09, 2021, 09:59:01 pm by mvs »
The following users thanked this post: kripton2035, adrko
  • Country: no
« Reply #18 on: February 09, 2021, 11:30:09 pm »
Thank you for the explanation, you made it very clear and easy to understand!
  • Country: no
« Reply #19 on: February 16, 2021, 01:25:18 pm »
Sadly there is no happy ending to this story:D
I have tried to order sample from the Coilcraft but they refused to give it to me because I'm not an engineer designing stuff - that's absolutely understandable!
So I went and purchased 10 inductors, my order went through, no issues whatsoever.
Then I get confirmation email.
Next day I receive a vague email asking me to describe my company and what the inductors will be used for, I did my best to provide an honest explanation.
And that's all that I have heard from them, been 7 days now, no response, package not shipped, no refund of my purchase.
Its a bit weird and unprofessional in my opinion, or am I simply wrong?
I completely understand I'm just a small fry whos ordering 10 inductors, but if its there and available to order am I wrong to assume that I will get what I have paid for?
Offline mvs
« Reply #20 on: February 16, 2021, 06:01:17 pm »
Coilcraft shop?
It sad, but just 10 years ago it was much worse.
Nowadays, you can buy parts as private person  in europe at least at some large distributors, like digikey, mouser, tme...
LCSC is also good place, if you do not mind to wait a bit longer.
By the way, why you have not ordered TDK MLZ1005M1R0WT000 from LCSC?
I do not like to play Madman Muntz, but this inductor is not very important part.
« Last Edit: February 16, 2021, 06:26:09 pm by mvs »
Offline slimmy182
« Reply #21 on: May 18, 2021, 02:29:54 pm »
Hello! Did you managed to fix this problem? After liquid spill my trackpad and internal keyboard was not working. Only switch a different trackpad and reconnect the old one do the trick! Now keyboard and trackpad works perfectly. Now the
Only problem remain the touchbar, it display image but wont accept touch control.
Looking in diagrams i found that there is a component lost:
Can be this the problem? Connectin an other touchbar won't fix, still display but not accept touch control
