I just started a project, where I will make a new controller for my air condition.
The simplest way I found to do this, was to just disconnect the existing controller, and keep all the high voltage control as it was.
To control fans and compressor, I got a 5 pin connector with gnd, 5v, fan high, fan low, and compressor.
I tried to google 5pin connector, and also tried with locking connector. I tried to find it on digikey too, where I am pretty sure it will actually be, but I think it is drowning in all the results.
Does anyone know what type connector this is?
