I got confused with the use as ZCD (zero corssing detector) and thought of a comparator. The circuit as shown is using the OP-amp as a follower, not a comparator. For this use a compartor would not be the right choice. One would want a real OP-amp, something like an MCP6001 / MCP6006 / LMV321 or any low voltage (usually CMOS) slow OP-amp. It depends on the later use of the signal if one needs the buffer at all.
A ZCD could use a comparator too, but this would be a different circuit and it dempends on what is done with the signal.
