Another vote for the DS1054Z.
It's an amazing value to begin with, which is improved if you hack it (enable all of the software options, double the memory, and bandwidth is increased to 100MHz). Really the best deal out there by far for an entry level oscilloscope.
BTW, your location would really help with posting relevant links for purchase locations and pricing. If you go into your user profile and set your country, it's flag will be displayed beneath your userID. Saves a lot of "where are you located" questions, and usually gets you answers faster as a result if it being pre-answered.
Based on your userID, I'd guess you're in Australia, and if this is the case, Emona sells Rigol. TEquipment.net also sells internationally however, so that *might* be a possibility.
