Hi, 40 yrs ago I bought a 1929 Sears house and put in a new boiler with a heating coil installed. Added a big red flow control fixture also. It made lots of noise, seemed to restrict flow and leaked just a little. So I took it out. The kitchen heated up a bit in summer as always when the family would call for hot water though. No biggie but just a little heat in the kitchen on a hot day is a pain. Now 40 yrs later, after paying movers 500 bucks to remove that rusted but still working boiler and being much older myself, I installed a new oil fired boiler. Took me twice as long to do the install and me fingers hurt like the dickens. But it’s running nice. So, But the question. I did not add a big red flow control valve. I’m considering adding a branch 10 ft of copper 3/4 , off a T with gate valves to have the option in summer to reroute the flow of heated water to the kitchen in a short 10 ft loop back to the furnace return run. Question. Without adding a noisy big red flow valve and instead adding a short return run employing a few valves and Ts, will this work? Essentially I’ll be using a shut off valve to shorten my standard home loop by over 90% and thus eliminate that little bit of heating in the kitchen, in the summer. When winter comes I’ll just open the valve and shut off the valve of flow back to the furnace return line. Just a standard old 2500 Sq ft home built in 1929. Thx, Tom
