I'm no good for computing exact values,
You don’t say…
Its hardly important at all to me! =) Alot of the time when I put caps in my circuits the actual farads dont even matter at all! And when I'm deciding resistances as long as the machine still outputs acceptably, a range of values is acceptable. I've got my next oscillator on the way, I don't know what the frequency will be exactly but as long as its oscillating that's the main part right?
It's very important, because you're getting bogus results most of the time. I could be mistaken, but I think the truth goes more along the lines of you being scared of doing the math, because that requires a modicum of formal education, even if it's self-education - you'll have to sit down with a book or an article and read through it and
actually be taught about it by somebody else, directly or indirectly, which is something I think you're too arrogant to bring yourself to. It seems that, in your mind, you're this unparalleled, misunderstood genius who can solve complicated problems intuitively in his head and with some trivial experimentation using nothing but capacitors and resistors. In reality, you're someone with a seemingly weak maths background, scared of complex numbers because you can't understand them, so you'd rather go around them than just accept and use them, just like you'd rather go around all of the well-established circuit theory and just throw stuff at the wall hoping something will stick (and not explode). You're free to do so, of course, but then don't be surprised when your ideas are met by others (or by reality) with resistance and/or ridicule.
Being afraid of learning will only set you back, you know.
