You don't say exactly what problem you are seeing.
The saturated NPN switch will be slow to turn off - is that it?
For a visual indicator, this doesn't matter and your circuit is fine.
If you are trying to generate fast pulses, a different circuit would be better. In that case, what are your actual speed and current requirements?
When you say it was tested in real life, did you build it, or just simulate it?
