I have posted most of these in the TEA thread but it will be lost forever in the 1112 pages and counting
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
It might be of use and get found here.
Got around to finishing my MacGyver 'Hack' version. Suits Hantek and Micsig 5mm Probes and should work for most other 5mm ones.
BNC-SMA adapter
6mm Brass Knurl Nut
Nichrome wire for the spring (tiny resistance will be insignificant as there is little current flow)
3D printed shroud (optional but adds a lot to the stability of the probe in use)
Remove the threads from the BNC-SMA so the knurl nut will slide on. Sweat the two together. The probe tip should comfortably sit in the end of the SMA section.
Wind a spring from the Nichrome. Wind the spring to 4.5mm (use a drill as the mandrel) and solder one side. Unwind a few spots on the Knurl Nut so the probe takes a bit of a wiggle to insert and solder wire number 2 in that spot.
Rough as guts 3D printed cover for the prototype works a treat the bulges are caused by the dodgy lumps of solder on the prototype
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
Quick test to 40 MHz looks good and even when bumped or wiggled still makes good contact. Waveform is full bandwidth no averaging so nice and noise free.
