Author Topic: NS resistor - do not stuff ?!?!  (Read 11452 times)
Offline SnakeBiteTopic starter
  • Country: il
  • OBSESSED MODDER
« on: May 16, 2014, 11:12:55 am »
 i saw in some datasheet a resistor that the value is "NS" and the description says "do no stuff" .
WHAT IT MEANS?  :-//
thanks
Ido
Ido Aricha , Israel.
Offline sleemanj
  • Professional tightwad.
Re: NS resistor - do not stuff ?!?!
« Reply #1 on: May 16, 2014, 11:27:30 am »
WHAT IT MEANS?  :-//
thanks
Ido
It means that part should not be installed on the PCB (by default, it may be required for testing, or some other option).
  • Country: il
  • OBSESSED MODDER
« Reply #2 on: May 16, 2014, 11:49:41 am »
Offline amyk
« Reply #3 on: May 16, 2014, 11:59:54 am »
I've also seen "DY" used as an abbreviation for "part not installed" --- would be nice to know where that convention came from.
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #4 on: May 16, 2014, 01:53:38 pm »
I usually see them marked as "DNI" for do not install or "No fit". There are a lot of reasons you might do that, generally when designing a PCB it's good to give yourself the option to make changes to the design in the future without changing the PCB.
You might also see "SOT" for select on test. That's normally a sign that it's either a prototype or a seriously marginal design that needs hand tweaking.
Offline krivx
  • Country: ie
« Reply #5 on: May 16, 2014, 02:09:13 pm »
I'm used to DNP for "Do Not Populate". Quite common when you think an amplifier might need a compensation capacitor in the feedback loop but can't be sure until you get the boards and build it, you put in a footprint for safety.
Offline theatrus
« Reply #6 on: May 16, 2014, 09:01:56 pm »
I've also use POP: Populate OPtion. Usually for multiple designs with the same basic board, or a designed-in-cost-reduction  |O
Software by day, hardware by night; blueAcro.com
Offline Lizerd
    • www.lizerd.se
« Reply #7 on: May 16, 2014, 09:05:59 pm »
Another standard is that the component value is "xx"
Offline David_AVD
« Reply #8 on: May 16, 2014, 09:08:15 pm »
I've seen DNF (Do Not Fit) and DNP (Do Not Populate) on a number of schematics.
Offline LukeW
« Reply #9 on: May 17, 2014, 04:46:10 am »
DNI, NP, DNP, DNF, POP, SOT, DY, NS...
It would be good if we could all come to one single standard for this which is understood worldwide.
Offline uoficowboy
« Reply #10 on: May 17, 2014, 03:45:53 pm »
You left out DNS! (do not stuff)
I agree that it'd be nice to have a standard. It seems like each company that I work for has their own standard for this.
