Yeah, green is marginal, but still okay.
Note the distinction -- "traditional" GaP green has an acceptable voltage drop (about 2.2V), high efficiency (GaInN) green does not!
Amazingly, GaP is so inefficient (or, at least, so much harder to optimize?), that it pays to use a higher voltage material entirely (GaInN is ~3V, normally emitting cyan to ultraviolet depending on exact composition), using either a microstructure or a phosphor to make green out of it (I forget how they do it exactly). Consequently, the green is a little different, usually more pure or "lime-green"-ish, in comparison to the slightly yellowish green of GaP. It's close enough you wouldn't notice independently, but side-by-side it's pretty obvious. Cool, huh?
