Well yeah it is an issue with contacts in switches and relay, a good quality connector though should produce a gas tight seal that lasts for years. Also I was always under the impression that wetting was a function of applied voltage not current. Basically you need a high enough voltage to punch through any oxide layer. This is why we have a bunch of relays with "dry" contacts, gold plating and the like.
As an aside; years ago I fixed a problem on a tool by simply replacing a conventional pushbutton contact block with a reed based element, contact block. The signal was TTL level and the problem literally went away for 15 years. It was a simple fix that no amount of contact cleaning and replacement would solve. On a problem more similar to what you are describing I had a CNC controller and its EPROM board create problem and solved that with some CAIG Deoxit sprayed into the EPROM board connector. Normal removal and reinsertion would not solve the intermittent problem but a quick spray and another reinsertion had the machine running for years. The point of this story is that connectors, even connectors designed for the job, create reliability problems.
Thanks, about 10 or so years ago, i went for an interview with Ultra Electronics in UK.....The Chief engineer brought up the subject of wetting in switches during that interview...and stated that it was a real issue to be extremely concerned about.
Most of the PSU's ive reverse engineered, in fact all of them, have the daughter boards soldered in...not with connectors.....this could be for cost...but also, could be because of wetting issues.
Soldered in connections, properly done, can be far more reliable than just about any plug and socket connector. This especially in the industrial sector where tools can shake the earth under you. I highly doubt that the concern is "Wetting". Frankly I could post dozens of cases (if I could remember them all) where connectors turn out to be the root cause of a failure, during my life in the world of automation. That doesn't mean that solder joints don't fail by the way, as there have been a few of them.
So no I don't think cost is even a factor, I'd vote for reliability. Think about it would you be happy if a transient across a bad connector trigger the crow bar on a power supply?
We are only doing a prototype, but if we get sometimes_intermittent joints for the signals. it will really screw up everything..specially since eg a feedback signal being absent could cause mayhem.
Exactly! This is why in my opinion the critical paths need to be on one printed circuit board in a power supply. I'm trying to think right now as to how many power supplies in the plant even have more than one board, not many that is for sure. A power supply can do a lot of damage if it supplies the wrong voltages to the main circuitry. Often power supplies are neglected in electronic designs which is sad because careful selection and implementation can eliminate a lot of issues.
