Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Which antistatic mat materials don't melt at soldering temps? [SOLVED]
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Which antistatic mat materials don't melt at soldering temps? [SOLVED] (Read 3731 times)
tyblu
Frequent Contributor
Country:
on:
January 23, 2012, 06:00:57 am »
I'm grabbing some antistatic matting for my workbench and soldering station. The options available to me from DigiKey are rubber, vinyl and laminate. Which of those best hold up to the heat? I'd like to not have to worry about solder balls, dropping a pen or putting down the heat gun.
The datasheet (
http://documents.desco.com/PDF/10200.pdf
) for one of the laminate contenders lists "160°F (71°C) continuous", which seems too low -- I sometimes crank the tip to over 380ºC -- but also says that it "resists hot solder". The vinyl one (
http://documents.desco.com/PDF/PM-127.pdf
) doesn't mention temperature. The 3M rubber datasheet one doesn't say much of anything (
http://goo.gl/Lr7Tm
Last Edit: January 23, 2012, 06:43:39 am by tyblu
Logged
Tyler Lucas, electronics hobbyist
ianxtreem
IanB
Super Contributor
Country:
Re: Which antistatic mat materials don't melt at soldering temps?
Reply #1 on:
January 23, 2012, 06:07:45 am »
In general, rubber resists heat well while vinyl melts.
All-Spec has a video on YouTube comparing the different kinds of mat complete with demonstrations:
Last Edit: January 23, 2012, 06:16:21 am by IanB
Logged
ianxtreem
tyblu
Country:
Reply #2 on:
January 23, 2012, 06:42:16 am »
Neato -- thanks.
After reading
this document [click]
I realize the matting listed as "laminate" wasn't referring to it being a composite material that had been laminated together, but the installation process: it is laminated to the work surface. I'm not doing that. Rubber it is.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
