I finally found a russian and english translation of the datasheet for these tubes. Does anyone have any idea how to make a simple driver circuit so I can drive these tubes with standard LSTTL logic like the 74LS47 or 74LS247. As I understand the datasheet these are open collector outputs? Could I use these outputs to possibly drive a transistor with a collector / emitter voltage of about 60 volts? I have no idea how to come up with this level shifter / driver circuit? Can anyone provide me with a schematic using the LS247 driving a transistor to handle the voltage of the anodes and grid. I suppose it would take 7 of these drivers for each tube for seven segments (a - g). Any assistance would be greatly appreciated. A picture of the circuit, a single stage, would be appreciated since I am not an EE. I spent my professional career as a Quality Assurance Engineer.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
BTW, the pinouts on the russian datasheet are not correct. I was able to statically get a single tube up and running but when I checked each anode they did not correspond to the pin out on the data sheet.
For anyone interested in the tube pin outs they are as follows: Pin 1 and 11 are the filament, Pin 2 is the Grid, Pin 6 is segment "a", Pin 5 is segment "b", Pin 3 is segment "c", Pin 10 is segment "d", Pin 9 is segment "e", Pin 8 is segment "f", Pin 7 is segment "g", Pin 4 is the DP.
