Author Topic: Repurposing LCD car DVD player faceplate screen? :P  (Read 3576 times)
Offline AmmoJammoTopic starter
« on: December 28, 2013, 02:06:37 am »
Trying to figure out if this LCD can simply be fed a video signal, but not really sure where to start....
I'm wondering if the DVD_C_IN and DVD_Y_IN are a chrome/luma input...
The AUX_L, AUX_R and AUX_CVBS run to an AUX input connector on the front panel.
SCL and SDA appear to be for the serial touch screen.
D+, D- and USB 5v are for a front USB port...
Anyway! not the point... does anyone actually know what the IC used on this is? :P
Offline amyk
Re: Repurposing LCD car DVD player faceplate screen? :P
« Reply #1 on: December 28, 2013, 10:37:50 am »
According to Google, that would be a Terawins T101A. Datasheet here...
Offline owl_uk
« Reply #2 on: December 28, 2013, 04:08:18 pm »
CVBS is probably the one you're looking for.  CVBS stands for something or the other, but its the same as composite video, i.e. the one you can feed from a single coax cable.
Offline codeboy2k
« Reply #3 on: December 28, 2013, 10:23:04 pm »
... and that chip is a Terawins T101A Video Display Controller, which happens to have 9 CVBS inputs (!) and is switchable by the I2C lines (SDA, SCL)
The Y/C lines also go to the chip.
The datasheet is attached. (zipped, 2 part RAR files)...
I had to split it (RAR) since the file size limit is 1MB per file and the datasheet is 1.3MB
I had to ZIP the 2 RAR parts since the forum only allows ZIP upload, not RAR uploads directly.
You can also get it here from Electrotanya, but you might need an account, thats why I attached it too.
http://elektrotanya.com/terawins_t101a_video-display-controller.pdf/download.html
« Reply #4 on: December 29, 2013, 11:42:18 pm »
Thanks for the assistance, I shall look into this further.
No clue why I couldn't find the datasheet :p
Might need to modify this a bit...
